Heating & Cooling Logo
Anonymous Posted on Mar 30, 2009
Error code 34... eventually error code 14
Error code 34...
Pipes/vents free- cleaned, probe... changed electronic spark module. Made sure all condensate tubes are free of blockage.
error still occurs
  • Anonymous Mar 31, 2009
    error code 34
    pilot proving fault
    error code 14
    pilot proving lock out
    items checked...
    disconnected all hoses made sure their was no blockage
    removed trap, cleaned with wire brush
    per start up instructions... added water to trap, added water to inductor hose unti water ran through trap. (furnace started and ran-turned off over night and furnace would not start again -same error code)
    replaced Carrier LH 33WZ 510 Spark Igniter sparker box
    cleaned with sandpaper pilot assebbly electrode (furnace started and ran-turned off over night and furnace would not start again -same error code)
    while opened checked orfice for blockage
    removed air filter
    checked pcv pipes for blockage
    checked for proper slope in PVC pipe (back to furnace)
    checked grounds
    events
    Start turn breaker on
    turn on switch furnace to on position
    raise thermostat to start heat
    blower motor begins (slight adjustments occur)
    few minutes inducer motor starts
    click
    error codes appear
    Gentle blow in pressure switch click can be heard
    Thanks
  • Donni Steen May 11, 2010
    What does the system say the codes are? All units are different.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Mar 06, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
2774
Points
How to fix error codes 14 &34 on Carrier Infinity furnace
Raylin Sutter
Level 2:
Sergeant:
  • Expert 107 Answers
  • Posted on Aug 27, 2015
Raylin Sutter
Expert
Level 2:
Sergeant:
Answers
107
Questions
0
Helped
278919
Points
610
I have dealt with a lot of AC trouble as well. With the heat this summer we decided to not put up with it and called in an air conditioning repair expert. Perhaps there is one around where you live? That would help you get this problem resolved. I tend to not do all of the fixing myself because that only makes the issue worse it seems. http://www.thurlowsheatingandair.com
Lou Barta
Level 2:
Novelist:
  • Expert 189 Answers
  • Posted on Apr 12, 2009
Lou Barta
Expert
Level 2:
Novelist:
Answers
189
Questions
0
Helped
83875
Points
298
The diagnostic code list shoild be on the inside of the door, next to the wiring schematic. See what error code 34 stands for.
Anonymous
Level 1:
  • Posted on Apr 29, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
2774
Points
My condirioner is STARWAY.
Display error E2.
please help mi.
Alketi
Top Heating & Cooling Experts
AskDyson
AskDyson
ADMIN Andrew
ADMIN Andrew
john h
