Dometic 3109228.001 Duo Therm Comfort Control 5 Button Logo
A
Anonymous Posted on Jun 30, 2013
Error code on my rv, the one of the temp buttons is sticking so I ordered a Dometic 3109228.001 Duo Therm Comfort Control 5 Button. when i plug it in I get a EE code on the display. I have unplugged several times, turned it off and on several times to no avail. help hot in ga.
5 Related Answers
Anonymous
  • 828 Answers
  • Posted on May 31, 2008
SOURCE: duo-therm by dometic ac rv unit
I suspect that you have a bad selector switch for the on, off, low fan, high fan operation. If the selector switch is put into the off position everything should stop completely.
Anonymous
  • Posted on Aug 02, 2008
SOURCE: thermostat wiring for second ac unit
I replaced one unite with another and the wires are differance colors the old unites wires are red,purple,yellow,bleck and white the new one have orange,brown,cream,darkpurple,and white
Anonymous
  • Posted on Mar 18, 2009
SOURCE: RV Dometic AC Comfort Control Double EE Problem
I have a dometic duo-therm. The unit works great and fan blows strong and both high and low work., but air is coming out of the ceiling unit rather than the duct work. The bedroom unit works OK, but the air is strong out of one duct, and not much comes out of the others. The front unit only has air coming out on the A/C unit and none out of the ducts.
Anonymous
  • Posted on Jan 05, 2010
SOURCE: Duo-Therm Comfort Control Buttons Not Responding
For a rebuilt Duo Therm 4 button CCC thermostat see
whendrix@aol.com
motor1258
Mike Butler
  • 6674 Answers
  • Posted on May 30, 2010
SOURCE: My Duo-therm Brisk-Air by Dometic rv ac wont cool.(The fan runs )
Usually just listening closely will give you a rough idea where to look for problem. When you have the fan on and switch to cool, (with temperature turned down low obviously) do you hear any type of "moaning" sounds from AC unit, or see lights in RV dim slightly indicating that compressor is trying to engage? Is the breaker tripping when compressor tries to engage? Do you hear a "click" from AC unit when switched to cool? If none of that happens, then I'd start thinking thermostat, or compressor relay. Normally if it's a faulty capacitor, the compressor will try to engage but will make a "moaning sound" and usually trip the breaker due to excess current draw. Someone experience in electrical should be able to test relays etc, but whoever does work on it, should be aware that those capacitors, as well as hydro in general are very dangerous to work with. The ("zap",- Shock) that you can experience from a capacitor or hydro, can be fatal.
Top Dometic Heating & Cooling Experts
jdthefixer
Ngoro
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
