Vehicle Parts & Accessories Logo
A
Anonymous Posted on Mar 30, 2013
Ec error code - Air Conditioning and Heat for AMC Alliance
What does the error code EC on a Defy top loader mean?
Errors TE, EC, TC mean that the temperature sensor that measures the temperature of the water in the unit is not working properly. Some codes - for example, TE - appear only before the start of the wash.
These codes are typical of both ordinary washers and those that have a drying function.
I have super general a/c from last few days it shut after 3/4 hours and display show EC and does not go unless it's is shut from main switch. What can be reason.
The EC error code tells you that your equipment has a pressure limit or the R410A refrigerant level is low. In this case, you must first contact a certified HVAC technician to check the pressure. If the pressure matches the gray label on the side of the condenser, your system has insufficient refrigerant. Make sure that the refrigerant charge in the factory is sufficient to cover this distance. Otherwise, you will need to add refrigerant.
Causes Of EC Error Code :
  • Refrigerant Leakage
  • Bad Internal and External PCB
  • Sensor
  • Bad Connection
Several reasons can cause EC Error. The main problem is usually a leak somewhere in the system.
3helpful
5answers
EC error code meaning
Hello friend, thank you for your inquiry!
I understand that you are getting an "EC" error code on your Frigidaire air conditioner. However, it appears "EC" is an invalid error code. It is possible that the error code is missing characters? I show that the error code "ES" or "CS" is valid. In the meantime, I suggest resetting your air conditioner. You can do this by flipping the household circuit breaker for roughly ten minutes. If resetting the power does not correct the issue, could you please inform me of the new error code or if your air conditioner continues to display "EC". I look forward to assisting you. -Matt
2answers
My orient split a.c shows Ec error in digital display
sir plz answer me my ac orien 1 ton showing EC error on display what is this i can't understand what is this plz reply
EC ERROR CODE
It means the unit is low on gas
2helpful
2answers
When i turn on my ac it looks to be working but 10 to 15 min later no work any operation and disply shown EC.
My is problems this is the mc indoor unit display by the EC errer code that a problem plz the help
2answers
My Sub-Zero is flashing error code 36. What is this?
Diarmait --
Technical Service Manual for the SubZero 600 series can be downloaded at:
[https://docstore.fedex.com/subzero]
Username=subzero
Password=subzero
Write back if you still need help.
-- SWT
3helpful
2answers
Our Bosch 2400E NG tankless water heater is displaying the EC code. I've checked the ionization electrode (rubbed it with a pencil eraser as instructed once before when we had this problem) and I also made...
Had same problem on my five year old water heater (ec error). Didn't figure it was a gas supply problem after five years but double checked to see if the gas bill was paid. It was.
Cleaned the contacts on the two sensors that are clamped to copper pipes inside. Still had error after powering up. Held the error button in for about five seconds, and the blinking EC code went away.
Top AMC Vehicle Parts & Accessories Experts
ADMIN Andrew
ADMIN Andrew
Kardoc
Are you an AMC Vehicle Part and Accessory Expert? Answer questions, earn points and help others
