Samsung WA5471ABP 4.7 cu.ft. VRT PowerFoam Top Load Washer in Platinum Logo
A
Anonymous Posted on Mar 25, 2013
Error code 8e - Samsung WA5471ABP 4.7 cu.ft. VRT PowerFoam Top Load Washer in Platinum
Samsung WA5471ABP XAA 01 Washer 8E error code
Sanmsung 8E error code means there is a connection issue with the main board lower wiring harness. Do not buy anything. Do this first. Open the back and check all the cables and terminals. Even if you just disconnect them and reconnect them. You may have to put the washer on its back to gain access to the bottom too. If you do not find anything, check all the cables with a multimeter. Took me 30 minutes to fix as a terminal had come off. The harness is a little too short so when you put a big load in the larger drum movement eventually breaks or pulls a wire loose. If you are unsuccessful, buy a new lower wiring harness.
1helpful
Fault error code 8E
an 8E or 8E2 means - Sensor problem.
1helpful
Samsung refrigerator error code 8E
8E = OVER CURRENT ERROR
IPM fault signal (this is caused by the overload of the MICOM INTO during motor action).
IPM: Integrated power module. The IPM controls the motor.
If the fault (low signal) happens to be sensed even once during the washing/rinsing stage, the motor stops immediately. However, during the dehydrating stage the signal is to be sensed, when the number of signals reads more than 6 per 500ms during the Washing or Rinsing cycle action.
If the motor stops working, in one direction ten times, "8E" Error is displayed.
During dehydrating, when the overload is sensed, the motor stops working at once and then feeds back to the initial stage of the dehydration unbalance sensing. When the feed back has occcurred twice, Error "8E" is displayed during the dehydrating unbalance sensing, No error happens by overload sensing. When it happens at more than 800rpm, the process is stopped compulsorily. Power Switch OFF can clear the overload error.
1helpful
E8 front loader washing machines
OVER CURRENT ERROR - Display shows 8E.IPM fault signal (this is caused by the overload of the MICOM INTO during motor action).
HOWEVER, the UK White goods website says:
E8
Temp too high on low temp washesNormally this will be the wash temperature thermistor or NTC that's faulty, please contact us if you need the thermistor with the model and serial number.
You can find more about your Samsung Washing Machine error codes at:
http://www.keepingupappliances.com/repair-help/appliance-repair/washing-machine-help/samsung-washing-machine-error-codes/
or
http://www.ukwhitegoods.co.uk/help/fix-it-yourself/fault-codes/laundry-fault-codes/3069-samsung-washing-machine-fault-codes.html
96helpful
6answers
Telewest codes sept '09 please
C2 B5 BE 41 0D 9B C5 7C+8E 80 D7 EF 44 93 02 2B
3helpful
E8 error code
8E - OVER CURRENT ERROR
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
233helpful
18answers
Need new codes for eurovoxmax need new codes dublin
codes for eurovox 5a01 6/5/09 aa b7 d1 d9 ce 8e 83 af a1 38 06 29 24 29 8d 2b should work ok bristol area
84helpful
5answers
Starview codes for telewest for today plez
telepest codes-
00-AA B7 D1 D9 CE 8E 83 AF
01-8E 80 D7 EF 44 93 02 2B
for 7/05/09
2answers
Error code 8E shows up just into the wash programme
8E is an overload or over current error code.. try unplugging it for a few seconds and plug it back in.. if it continues you could have s short in power distribution block on the board.. I would recommend if it continues for you to call a tech im sorry to say.. Good luck
Top Samsung Washing Machines Experts
Grand Canyon Tech
Grand Canyon Tech
Sudeep Chatterjee
Sudeep Chatterjee
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
