Bissell 1960-3 QuickSteamer Plus Upright Vacuum Logo
CHERYL MURPHY Posted on Jun 13, 2007
Quicksteamer husband filed directions for use somewhere and i can't find them... neither can he. how do i set up the machine for use? i vacuumed area 1st. i have bissell fiber cleansing formula and bissell multi-allergen removal formula beside me. Plus a quicksteamer my friend used and returned with the directions, but she is not available for a week. hmmmm.... besides going through the den trying to find something in the chaos therein, the alternative is... YOU! :) thanks.
  • luanna-j Sep 02, 2008
    please can any one tell me how to use this
  • Anonymous Sep 08, 2008
    need to know how to operate
Anonymous
Level 1:
  • Contributor 32 Answers
  • Posted on Jun 13, 2007
Anonymous
Contributor
Level 1:
Answers
32
Questions
Helped
13417
Points
77
Below is link to the directions for use for your vacuum: http://www.bissell.com/images/UserGuides/2070.pdf Just download to your computer and view with a pdf viewer or print it. Good luck.
Water leaking from somewhere on my bissel quicksteamer model #1970
This is not an easy one for us to offer advice on because we cannot see it. There are a lot of places that can leak water and there are a lot of parts that can wear out. You need to check the hoses and connections on all the tanks and spray bars. At least you can get parts for it now: http://www.vacsite.com/en/bissell-parts-1/bissell-parts/1970-quicksteamer.html
Apr 22, 2016 • Vacuums
My bissell quicksteamer makes a high pitch squeal
Something is caught in your beater bar , causing preasure on another part of machine. This contact is the cause of the noise. GOOD LUCK FRIEND.
Sep 16, 2014 • Vacuums
1helpful
Manual for Bissell quicksteamer.
Hello, this is Ava with Think Crucial.
You may find the User's Manual for your Bissell model by clicking the link below.
Bissell QUICKSTEAMER 1950 User Manual
You can purchase a wide variety of high quality Bissell replacement parts for your Bissell vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/collections/vendors?q=Bissell
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Mar 19, 2012 • Vacuums
What's your problem? how to replace nozzel for bissell quicksteamer
The User Guide for your Bissell 1770 QuickSteamer can be found here:
http://canada.bissell.com/images/UserGuides/1970-2080_English.pdf
Available replacement parts may be ordered online here:
http://canada.bissell.com/Products/p/1770+quicksteamer/ak/replacementparts/Product.aspx
Was not sure if you meant you were having difficulty with actually removing and replacing the nozzle? Please reply if you need further asistance
When i turn it on the motor makes laud noise
Mine did too. Eventually it started smoking and spat-out dust from the dead motor.
I wish I had looked at the motor and added some vaseline or something before in conked-out completely.
I think the problem was that I was not spraying water enough and so running the machine more as a dry vacuum. Maybe this allowed the motor to spin too fast and over head. Or something.
New motors are available but cost nearly as much as a second hand quicksteamer / quickwash.
Need to download PDF format Parts Manual for Bissell 1950-3 Quicksteamer plus -- is there one available?
BISSELL User's Guides can be downloaded at www.bissell.com
On the front page under Customer Service click on User's Guides and enter the model number of your unit.
User Guide will be displayed as a PDF file.
1helpful
Bissell manual
Sorry this is as close as I could come...but *** covers the Quicksteamer 1970 model...and surely it is the exact same process for yours...as this manual covers several models.....I found it at www.bissell.com.....I hope this helps...good luck and thanks For rating my effort....The Fang
http://www.bissell.com/images/UserGuides/1770_0206.pdf
I have a Bissell Quicksteamer
Find some shop where you can order a bissell part, 2035617 is the part # for the owner manual. A pdf file is no longer available.
1helpful
Bissel 1770 Quicksteamer II Upright vacuum
Here is a picture breakdown, maybe that will help. Sometimes tho you can run a mixture of vinegar and hot water thru it, it may clean it out ok.
Diagnosing the problem with my bissell quicksteamer plus upright
Was the exposed copper wiring on the electrical cord? If is then replace the cord. The main problem with this model is that Bissell obsoleted it as well as parts for it. But if all you need is a cord, you should be able to get one from a repair shop.
Top Bissell Vacuums Experts
Renee Knafel-Bullock
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
