I'm trying to convert a document that i have scanned to a pdf file. It tells me that the ocr program is missing and to reinstall it from the cd. I have miss placed the cd somewhere, what are my options??
SOURCE: ocr folder
The software you need is Abbyy Sprint OCR. If it's not installed, I suggest running the printer setup again, making sure it's selected when you get to the software list. Perhaps you unchecked the box when you ran the installation the first time, or didn't know what it was and uninstalled it from your computer. You may be able to find it by hunting through the CD, but it will probably be easier to run the setup again.
SOURCE: Lexmark X2500 driver is missing OCR software
Sometimes companies only support only the basic drivers. The OCR software is on the CD (s) that came with the printer. Suggestion. Try to order the original CD from Lexmark., or search Ebay for programs that have OCR capability. You can use OCR programs from other vendors as long as they are stand-a-lone programs. Just make sure you have the original disc so as not to infringe on copyright privileges.
Note: you can buy OCR programs. Check Ebay and Amazon. They are usually better that the programs that come on the OEM disk.
Cheers.
SOURCE: X5495 - OCR Program Missing.
Do you have MS Office 2003 or 2007? If so, there is a Microsoft Document Imaging tool that you can use to scan text documents. You can also search www.download.com for free OCR tools you can use for the same purpose.
SOURCE: ocr software missing. did not scaning
You can install the OCR software from the CD. Run the Setup and you should probably see an option to install "Additional software". Choose "Abbyy...", this is the OCR software you need.
If you don't have the CD anymore you will probably have to call Lexmark Customer Support to order one. I don't think the OCR software is available for download.
SOURCE: cannot scan document and save as PDF file
The only way you can install the Lexmark scan software (OCR) is by using the installation cd. It's not available for download on the internet. If your computer is not recognizing the installation cd, I suggest you contact Lexmark Technical Support to request for that. They can send you one for free. Hope this helps.
