Big Button remote control have pre-programmed with 3 digit codes. There are no code for Insignia tV with it. Codes for this TV are:
0103 0189 0217 0135 0133 0116 0167 0456 0029
Anyway try a code search method. Some times, ti might help you.
Code Search
If after trying "Direct Code Entry" your device does not respond, or if your
brand is not listed, try doing a search of the code library for your code by
following these steps.
Most users will want to store VCR codes under the VCR button, Cable codes
under CBL, etc. If you want to store a VCR code under CBL, etc., first follow
the procedure for Direct Code Entry and press CBL in step 2 of Direct Code
Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the
steps above for Code Search.
SOURCE: Codes for Big Button Remote
If it's an Innovage brand Jumbo remote, try this...
There are 2 different versions of the Innovage Jumbo remote, an old and a new.
For the old version:
1. You have to have the TV or DVD turned OFF.
2. Then, you have to push CODE SEARCH button once for 3 seconds till it lights solid
3.
Then press TV (or DVD) button once till it lights once and turns solid
and press the ON/OFF button very slowly and repeatedly as many as 300+
times to wait for the TV (or DVD) to go on.
4. Once it goes on...STOP and IMMEDIATELY press ENTER before you pass up the code or you'll have to start over!
This
is very frustrating but my advice is to take it slow and methodical.
Think the tortoise and the hare...if you go too fast, you'll redo it
several times because you'll keep passing it up and accidentally turn
the TV on and off suddenly and miss the code.
For the newer version:
1. Turn the TV (or DVD) ON.
2. Press CODE SEARCH once and it blinks.
3. Press TV (or DVD) once and it blinks.
4. Press ON/OFF button only ONCE.
5. Wait as it automatically searches for the code by itself. It will have a slow long blink between each code it searches.
6.
Stay alert because when the TV (or DVD) goes off, you IMMEDIATELY have
to push ENTER to lock in that code before it goes onto the next one.
(which it will even if the TV is off)
SOURCE: NEXXTECH 2 IN 1 BIG BUTTON Universal REMOTE CONTROL TV code for sansui tv
Have a solution for you.Turn your TV on then Press and hold 'P' on remote until light stays on. Press device to be controlled (TV/Cable) light will flicker but stay on. Now keep pressing channel up (up to 300 times) until device changes channel. Then press Enter to save code. Hope this helps
SOURCE: my remote is a bowtie big button remote and i
These are the codes I have for Sylvania TV's... see if one works.
0062,0064,0009,0135,0189,0183,1141,0227,0456,0008,0068,0075,0141,0161.
SOURCE: need emerson jumbo big button
Hello 001 015 016 018 001 003 040 060 088 145 231 232 233 234
Codes for Hitachi TV with Emerson remote control are:
029 043 072 147 204 207 226
For Philips TV are:
235 236 247
OK.
