Televison & Video Logo
Anonymous Posted on Jun 16, 2012
How can i program a universal remote control for my sylvania tv?
I have a sylvania analog tv and I want to program a universal remote control for changing channels and volume.
Level 3:
Top Expert:
  • Sylvania Master 76,851 Answers
  • Posted on Jun 17, 2012
Sylvania Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
15380470
Points
237768
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Code Search
If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
5 Related Answers
Anonymous
  • Posted on Feb 10, 2008
SOURCE: programming a universal remote control for a tv
The code for a Sanyo TV set should be 100. Press and hold the TV button on the remote while entering the code. The light should blink 5 times if it was accepted, and then you can test to see if it worked.
A
Anonymous
  • Posted on Apr 07, 2008
SOURCE: iwave big universal remote codes
I need the codes for the Phillip Magnavox tv combo.
Anonymous
  • 8 Answers
  • Posted on May 25, 2008
SOURCE: Program codes for tv and satelite.
https://fjallfoss.fcc.gov/prod/oet/forms/blobs/retrieve.cgi?attachment_id=305485&native_or_pdf=pdf
The manual
A
Anonymous
  • Posted on Jul 07, 2008
SOURCE: HAVE A magnavox tb100mw9 for
Found a solution that works well...
I picked up a Sony RM-VL600 universal remote with learning capability. With this unit, I've been able to program all the functions of the TB100MW9 DTV Converter box.
I picked up this unit at Walmart for $25, but have seen it on Amazon for as little as $16.
This remote is a vast improvement over the remote that comes with the Magnavox DTV converter, and was easy to program.
Anonymous
  • 5 Answers
  • Posted on Oct 12, 2008
SOURCE: RadioShack Universal Remote (Cat. 15-2147) - to use with JVC TV
programming a device: make sure batteries are installed correctly. Turn device on(for ex., your TV). Press TV button next to Power button on your 15-2147...Press and hold the little P button until the red LED lite blinks twice...enter the first four-digit code for your device(in your case,JVC TV...first set of #s is '0463' ) note: the LED will blink once as each number is entered. If the number is correct the LED will blink 2x. Note if the LED doesn't blink twice after entering the 4 digit code, begin again with the next set of numbers. For JVC the codes are 0463 and 0053. Once your remote blinks twice after entering in your TV code, press the power button. This should turn off your TV. Just use like any other remote. Hope this helps you.
Top Sylvania Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
