Without a specific description of the file format or file size limit, a good way to test what works is to create some very short files saved in different formats on your PC then load them on your memory card to see which ones work. Usually formats like .WAV, .SND, and perhaps some others may work. They can be easily saved to test on your PC.
The main SAVE AS considerations are:
Extension;
Format: as in PCM, and about some 18 others; then
Attributes: frequency, bit-rate, and Mono vs Stereo
Windows basic sound Recorder will let you load a sound file and save it in different formats [with some limitations] but enough to experiment.
SOURCE: memory card micro sd cannot format
i found something to fix it. or at least it worked for me
http://hddguru.com/download/software/HDDGURU-Low-Level-Format-Tool/LLFsetup.2.36.1181.exe
Install that, then run the program and CAREFULLY select your card from the formatting list
then do a low level format
Then format it on windows or phone or whatever
PLEASE BE CAREFULL NOT TO SELECT YOUR HARD DISK IN THE PROGRAM. IT WILL VAPORIZE ALL YOUR DADA
SOURCE: Cant copy phonebook contacts from sim card to phone memory?
Go this way
Menu > Phonebook > Options
Scroll down to Move and select.
Select Multiple from the pop out.
In the list just check All or whatever contacts you want.
HTH
SOURCE: i want to recover contacts from n73 phone memory after formating
what you can do is use a recovery software like GetDataBack but my friend it seems like they've gone cuz the data recovery for hard drives is very low so memory cards have very little chance...
SOURCE: Unable to add default folder - Memory Card
take the card out and put in back in. it worked for me,
SOURCE: n70 memory card corrupted
Hey the problem might bewith tht type of file system u r formating it to try formating it to different types of file systems...
