SOURCE: ZANUSSI WASHING MACHINE
seems to be a problem with the filter. was with mine.. one thing i always forget to clean it regularly.
Be careful when open the little hatch thingie , there will be water coming out . so prepare with a bakingtray and kitchen towels. and open it SLOWLY!!! so the water doesnt totally soak the floor.
then clean clogged up filter. at least that solved the problem in my case, hope it works
SOURCE: Zanussi Turbodry jetsystem 1200
hiya
e90 means there is a communication error between the circuit boards inside. remove the plug then take the lid off the machine, remove the block which has the 5 (iirc) blue wires in it and give it a quick squeeze then replace, this should hopefully solve your problem.
hope this helps
please dont forget to rate the helpfulness of this reply, thanks kj
SOURCE: hi zanussi fjr 1254 w error code e90 what does
This error code seems to be the control board detecting a wrong
configuration (in other words, an illogical set of sensing conditions,
from its connected sensors and wiring). It apparently can happen, when
wires become badly contacting, or if contaminated with motor brush
carbon (the horrible black powder that comes off the motor commutator
and brushes), or corroded from other contaminants from the soap
dispenser area. You should be able to check this, remove, clean and
replace the contacts:
Thanks
SOURCE: e10 flashing up on my zanussi jetsystem progress
The reason to this problem is due to the electric valve.
The old unit might have gone bad,replace it with a new
one.
SOURCE: I have a Frigidaire Gallery front load washer with E10 error code
When ours does that it is because of the hard water build up. We have to un-hook the hot water clean out the minerals and it stops doing it.
